Need some rebuilding advice
I'm really not looking for much more than a head/cam build, however because I do not know this history on this motor, I fully disassembled it to clean and inspect for possible issues.
Results:
- Bearings are pristine (literally near zero wear)
- some (not fresh but clearly visible in areas) crosshatch remaining
- no cracks/damage to rings/pistons
- no other indicators of damage that I can see
So, my question are:
- what do I NEED to do?
- what can I reuse?
- what must to be replaced?
Can I:
- reuse main bolts?
- reuse rod bolt?
- reuse rings/no rehone?
- reuse bearings?
I plan to:
- replace head bolts with studs (I prefer studs, personal preference)
- get MLS gaskets (since they are reusable)
- mill the heads to get up to around 10:1
- run TR224/224 on 112LSA
- good drop in dual valve spring
- stiffer pushrods
The goal is a good streetable (daily driver) around 385-400rwhp N/A with 6800RPM shift point.
Side question:
- Since I got this thing so cheap, I have the money left over to grab up an aluminum 5.3 block. Can I just swap all the guts over from the iron to aluminum block and go? I assume I would need to cross-hatch and re-ring since I would not be matching up pistons to original bores.
