Please help t56 trans drama
Old Mar 8, 2013 | 05:06 PM
Hydrojunkie's Avatar
Default Please help t56 trans drama
I have a 2000 ls1 from a camaro
Recently purchased a t56 out of a lt1
Recently purchased a 2002 clutch kit " hydraulic throw out "
Just found out it won't work.
What can I do to get it right. Please help
Old Mar 8, 2013 | 05:08 PM
HioSSilver's Avatar
Change the front plate and input shaft to make it work.
Old Mar 8, 2013 | 05:19 PM
I'm dumb
The front plate is where the Hyd throw out bearing bolts to.
Do you have any part number. My friend is a gm tech. He can order the parts.
Old Mar 8, 2013 | 05:25 PM
Can I use the ls clutch in a lt bell housing?because I can get the lt bellhousing
Old Mar 8, 2013 | 08:01 PM
Anyone
Old Mar 8, 2013 | 08:27 PM
lizeec's Avatar
To put a LT1 T56 on a LS1 engine you need to change the bell housing, front plate and input shaft, the parts will run you between 4-5 hundred new, and the people that have used parts usually know what they have and want close to new prices for their stuff.
Old Mar 8, 2013 | 08:37 PM
Thank you. Wish I never got involved in this tranny
