Need help w/head choice for ms4 cam
The larger valves are probably heavier than the stock GM valves. I also don't think you gain much in the way of flow, so you lose a little velocity at the valve as well as piston-to-valve clearance due to the larger valve. One thing you gain is probably flow at higher lift levels, which might be a good fit with the MS4's lift.
If you are considering the 2.5s, might as well spend the extra $100 and get the PRC As-Cast 225s. I think it flows more out of the box and provides much better PtV clearance for more compression for just a little bit more money.
