Throttle Body Size of 5.3L in mm?
Old Mar 14, 2013 | 01:56 PM
Z28-Vortec's Avatar
Default Throttle Body Size of 5.3L in mm?
Hello,
Hopefully someone can answer this, googled for an hour with no luck.
I am trying to find the actual throttle body size in mm of the 5.3L truck motors.
I know that the LS1 is 78mm, but can't find anything on the 5.3L Throttle body size. Is it the same size?
Does anybody know?
Thanks
Old Mar 14, 2013 | 02:30 PM
chrisfrost's Avatar
When You say the LS1 is 78mm , have You measured it ? Because I believe it's actually closer to 75mm and the LM7 5.3L throttle body at least Mine was 70mm in factory form . That's actual measurement , not sure what They list it at . I ported mine to 74mm and polished the sh_t out of it .
Old Mar 14, 2013 | 03:03 PM
Z28-Vortec's Avatar
When I was searching the only size for the LS1 I found was 78mm, but that could be wrong also. I haven't found a place that states the actual dimensions either.
Thanks for the help, if it isn't that much differences anyways I'll just port and polish one.
Old Mar 16, 2013 | 12:17 PM
RezinTexas's Avatar
my '04 LM7 DBW throttle body was 74mm
Old Mar 16, 2013 | 03:29 PM
96capricemgr's Avatar
I believe they got larger yet on the later motors.
Old Mar 16, 2013 | 05:57 PM
Z28-Vortec's Avatar
K, I was debating a LS1 throttle body or a 5.3l one. Since it doesn't seem like much of a size difference I'll just get a 5.3l and port and polish it. Budget build anyways.
