best cam slection
Old Mar 8, 2003 | 02:46 AM
408 Stepside 01's Avatar
Default best cam slection
I have a question for you guys.I am in the middle of swaping out my 5.3 with a 6.0. I had a whipple with 16 lb of boost on my 5.3. I used the ls6 cam with 8:1 compression and saw a noticable difference, but i want to build this one a little more radical cam for this motor. I just pulled out the 5.3 and i am building the 6.0. I was wandering what cams have worked the best for you guys. I am using the heads off the 5.3. I put 2" intake valves in and ported the exost. I am also going to run a procharger instead of the whipple. The whipple is on ebay if anyone is interested.
