Tach not working in gauge cluster
Old Mar 26, 2013 | 05:19 PM
IMPRTKILLER's Avatar
Default Tach not working in gauge cluster
My tach was working fine then one day it started to act up. Now it doesn't work at all. When u turn the key on it moves down. I replaced my cam sensor and my crank sensor but no luck. I even traced the wire from the PCM but not luck
Old Mar 27, 2013 | 10:41 PM
v8 that rex's Avatar
Where does your vehicle get it's speed reading?
VSS - check the sensor located at one of your wheels
ABS - check for corroded wires or faulty module
Trans - check the connection to your trans
