5.3 lm4 with ls1 cam
Old Apr 8, 2013 | 10:13 PM
cmoulton's Avatar
Default 5.3 lm4 with ls1 cam
hey guys new to the forums and came here wanting to ask a quick question. so over the weekend i picked up a slightly built 5.3l engine out of a 2002 Tahoe its got a comp cam xfi rpm hi lift cam ( 54-424-11 to be exact ), ported and polished heads, larger valves, comp valve springs and push rods. well after talking to the previous owner he informed me that it has a ls1 cam in it and not a 5.3 cam. Ive been searching around but cant seem to get a clear answer. i believe the 5.3 cams have the 3 bolt while the ls1 cams have the single, but i was wondering can the ls1 style cam work properly in this motor without a timing set and timing cover with crank position sensor from a ls1?
Old Apr 9, 2013 | 05:50 AM
LS5.3stang's Avatar
my 2003 5.3 had 3 bolt . 1 bolt didnt come out till later years. same cam design
