Running Untuned with Bigger Injectors?
Old Apr 12, 2013 | 07:24 AM
maxpower_454's Avatar
Default Running Untuned with Bigger Injectors?
Would the car run ok if I ran my H/C combo with 42lb injectors untuned for a little while? I'd like to know everything was ok before I slapped it on the dyno.
Old Apr 12, 2013 | 07:45 AM
pauls99z28's Avatar
No you will foul the plugs.. Just slap on the stockers until you go to the tuner and install the 42's at the tuners for tuning.
Old Apr 12, 2013 | 08:04 AM
Thanks. I just called my future tuner and he recommended the same thing.
Old Apr 12, 2013 | 08:14 AM
pauls99z28's Avatar
No Problem. keep us posted with you results.. what setup you running if you dont mind me asking?
Old Apr 12, 2013 | 10:13 PM
Here's my build thread:
https://ls1tech.com/forums/generatio...h-c-build.html
I didn't update it much lately since I've been working on the car so much but will soon! I hope to fire it this week.
Build specs:
Gm 243's AI ported to 232cc, 62cc chambers
Cometic 3.910" Head Gaskets - .040" thick
AI Cam 228/234 .600 .600 cam
PSI Beehive Valve Springs with Manley Titanium Retainers
LS7 Lifters
Hardened CrMoly Pushrods
Comp Cams trunion Upgrade kit
LS2 Water Pump (For future FAST 102 install)
GTP Injectors
Kooks 1-7/8" X 3" Stainless Headers
AI Ported LS6 Oil Pump
Racetronix pump
