Egine not making ANY power
- Matt
Sean M from Maryland knocked off a 1/2 a second switching to AS heads over PP heads.
Name your 2 Terry. I named 2
Mike M,
I know the real story about HPA,I talk to John quite often.No one has lost any account.When the car had Patriot Stage 2 5.3L and dynoed,then had AS 5.3L heads installed the car made the same HP but lost torque.After dynotuning was performed the car made the power difference,not because of the heads.
Sorry this is off topic.I will not make any more post in this thread.
Someone mentioned overheating could have caused the previous set of heads to warp. How did you blow the head gasket? Also, what does the oil look like? If the car got overheated enough to warp the heads that bad, then it may have cooked some bearings someplace.
I agree with a couple of the other posts, after checking your oil for signs of bearing trouble, the first best thing would be to have the computer tune checked and rematched to your new higher flowing heads. Then if you're still down on power, start looking for mechanical gremlins. The motor overheating could have caused some serious trouble. Problem with today's all aluminum motors is that they're really sensitive to overheating. If it overheated enough to warp the heads, it might have warped the deck of the block.
John Woodward
Owner
HPA
On topic, I'm thinking it might be the pushrod length which maybe slightly off, I'm bringing the car out to jay sometime this week or next(what ever works for him) and I will let everyone know how things turn out. Jay said he with the vette Dr's tuning will make the 450 rwhp the car should be making, and I have no doubts he is right. I cant wait
