WTF :bang:? New 408 Problems
Old Apr 28, 2013 | 07:30 PM
lemons12's Avatar
Ah.. I knew there was three things.. And my knuckles hate that bolt.
Old Apr 29, 2013 | 04:03 PM
Sinister_Z28's Avatar
Thanks for all your input guys. So i will recheck all my grounds and see if anything is loose. So if it isnt a ground what else should i check?
Old Apr 29, 2013 | 10:10 PM
I checked my grounds and found that the ground behind the drivers side head was loose so i tightened it. Ill just have to see if that fixes it.
Old Apr 30, 2013 | 12:47 AM
mannyman84's Avatar
Seems like you are probably losing fuel up top. Check your fuel pressure. And for the Trac off light I would say probably module is taking a ****.
Old Apr 30, 2013 | 12:48 AM
mannyman84's Avatar
Your ABS module that is.
Old Apr 30, 2013 | 02:56 AM
I tightened the ground on the back of my head and the ASR light didnt come on cruising to work. As far as fuel preassure goes i think when i get it back for a full tune that will take care of it. So are the three ground wires all supposed to be on the drivers side head or is there supposed to be two there and one on the passenger side head?
