need help ASAp!!!!!!
arms at the bottom that were barely able to reach the inner spring. Do a search for the
Larry tool, it bolts to the rocker arm stud and compresses the spring down. Maybe you could fab something up real quick. Good luck.
https://ls1tech.com/forums/showthrea...ght=larry+tool
there is a pic of the tool so maybe you could fab one or just e-mail the guy and he could send you one.
Need to get one of the spring tools that mounts to the head and compresses the spring without grabbing the coils.
I tryed to use a look a like "LARRY'S TOOL" the only bolts and nuts I could find would bind and pull the threads on the bolt after only used on one spring , there after I drug out the welder
good luck Johnny
