243's on stock ls1 motor?
Old May 20, 2013 | 10:43 PM
1_MEANZ28's Avatar
Default 243's on stock ls1 motor?
have a set of stock 243's i was thinking of just swaping heads only on my 98 camaro ls1,for now,meanwhile i do cam and my other plans on it.
my question is is the time worth it? rwhp
any downsides of just swaping heads only ? would i need a tune after i swap them?
thanks in advance
Old May 20, 2013 | 10:47 PM
97camaro383's Avatar
thanks in advance
I'd wait and do heads/cam at the same time! Id assume you'd need a retune if you did do it though.
Old May 21, 2013 | 12:08 AM
D14HUGGER.ORANGE's Avatar
You can gain 15-20 hp maybe more with stock 243s.
Old May 21, 2013 | 04:20 AM
2000PewterT/A's Avatar
Wait until you are ready to put the cam in then do the heads, that way you can do the valve springs while the heads are off and do the lifters too.
Old May 21, 2013 | 04:24 AM
lemons12's Avatar
20Rwhp..
Old May 21, 2013 | 05:03 AM
Grimes's Avatar
My friend did this a while back. Engine definitely felt "peppier", but if you can wait, I would definitely get them ported.
Old May 21, 2013 | 07:37 AM
maxpower_454's Avatar
+1. It's a crapload of work and if you have as little time to work on your car as I do, you'll definitely only want to tear it apart once.
Old May 21, 2013 | 07:43 AM
Alvin@PCMofNC's Avatar
LS1Tech Sponsor
About 20 rwhp! Have them ported and do a cam at the same time if you can.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old May 21, 2013 | 07:55 AM
HCI2000SS's Avatar
Since you already have them wait and get them ported for sure
Old May 21, 2013 | 08:13 AM
badazz81z28's Avatar
Your gains will be in the cam. The 405hp Z06 engine is nothing more than a LS1 with 243 heads. If you swap the heads, do the cam too.
Old May 21, 2013 | 02:16 PM
Justhereforinfo's Avatar
So the cam and intake are the same?
What about the exhaust manifolds, injectors, throttle body. Same? Same computer too?
Old May 21, 2013 | 04:24 PM
garygnu's Avatar
do a valve seat leak test ,get a valve job if any of the valve seats leak.do it all at once ,pay for only 1 tune .
Old May 21, 2013 | 05:00 PM
SNLPerformance's Avatar
If you put them on "stock" you will notice a difference. They are a big improvement over the stock 98 heads if that's whats on the car now. As far as porting goes- more money more power. Its the name of the game after all. IMO send them out to TEA or AI or WCCH and get them ported if you can. Then tune it 1 time versus 2 if you pull the heads to port them. Either way it needs to be tune if that makes sense.
Old May 21, 2013 | 05:34 PM
joecar's Avatar
Your gains will be in the cam. The 405hp Z06 engine is nothing more than a LS1 with 243 heads and 308 cam. If you swap the heads, do the cam too.
Corrected.
( technically, the Z06 also has the LS6 block, intake manifold, valley cover and PCV system, and a different PCM calibration )
Old May 21, 2013 | 05:38 PM
joecar's Avatar
No, the cam is the LS6 cam, and the intake manifold is the flat-bottomed LS6 manifold... and the Z06 has vehicle specific exhaust manifolds.
Old May 21, 2013 | 05:39 PM
low2001gmc's Avatar
MASS seller approved
x2. do it all once and save on labor and tune....
Old May 21, 2013 | 08:28 PM
Originally Posted by joecar
Corrected.
Depending on the year, yeah the block was improved, but no power to be had there nor in the PVC system.
What I was trying to say, slap on the 243s and the LS6 cam, you will have the 400hp. "LS6" and "LS1" are just engine codes. They are the same bore X stroke,
