Engine Build #1: Input from LSx junkies
Stock block - stripped, hot tanked
Stock Crank - Polished only (journals are in good shape)
Stock cracked rods, ARP bolts, line honed 0.002in
Stock pistons
New rings (forget brand, came with moly top ring)
New standard clevite cam bearings
KING bi-metal main and rod bearings (rod bearings 0.002 OD oversized, STD mains)
Home Port and polished low mileage 317's w/ 3 angle valve grind
Stock valves, retainers, lockers (very low miles)
LS9 head gaskets
LS2 lifter trays
LS7 lifters
PAC 1518 Springs
Stock rockers with trunion upgrade
LS6 intake manifold
LS6 baffled Valley Cover
ALL new gaskets and seals
Stock LS1 ported/smoothed and shimmed stock oil pump
Stock modified truck pan w/ stock modified pickup
Cam (still running numbers, not sure yet)
Chromoly pushrods (have to measure and determine length)
Low mileage knock sensors
NEW Oil pressure sending unit (Is this just for the gage readout?????)
LS2 timing chain
New stock LS1 crank and cam sprockets
Those are the plans, and most of that stuff has been acquired and machining will start this upcoming week.
Any input is appreciated. I have a MSME and design compression ignition engines for a living, so please give me any input, as technical as possible so I am not overlooking any notorious issues with the LSx platform that I could miss. I might look into chamfering the oil ports on the crank main and rod journals to improve oiling as well if it is advised on these engines. Thanks in advance!
If you can stretch the budget, I would also do some basic forged pistons but that's not absolutely necessary at low boost.
