Looking for a good DD cam suggestions?
Predator-z, if I were to get 99Bluz28's recommended cam with a ls2 timing chain/gear set would I be ok to line them up Dot to Dot? I'm trying to make sure I do everything correct the first time so I don't have to do it again. So sorry for all the questions guys I'm still learning.
! Lol, there is one thing that has me worried about installing the cam though; that being degreeing it. Wouldn't you just line up the timing marks to install it? Making sure the engine is at TDC?If you don't have time to do it yourself let us know. Typically we have you out the door with a before/after full dyno & street tune, fluids, gaskets, springs, pushrods, custom cam, tax, the whole 9 yards for $2200
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
I've never had one that was much more than a degree off but it is a good idea to check.
I ended up going with the custom cam recomended by 99Bluz28 (thanks by the way man) LSL 227 intake lobs and LXL 230 exhaust lobes on a 111lsa with a ICL of 108. Enjoy!
BTW my car is what I would consider fairly quiet for having H/C/I, ORY-pipe an LT headers.
http://s523.photobucket.com/user/RDB...043c3.mp4.html
With a lower idle and your SLP LM exhaust you'll hear it a lot more clearly.
http://www.coloradospeed.com/hawk-ls...3-p-10976.html
As long as the dog bone shaped seal on the retainer is not damaged, no you don't need to replace it.
Removing the radiator and what not.
Timing cover and all that good stuff removed.
Then finally how she sits right now, I was kindly amazed how the lifters just sat up in the lifter trays (I think that's what they are called?) once I spun the cam over a few times I have some wooden dowels I will be using to hold them up of course.
Here's my current work station, those saber lights come in real handy!
I plan on getting it all wrapped up tomorrow, I will keep this thread updated with some pictures though. I'm dreading the valve spring install to be honest but hopefully it will all go smooth.
out with the old in with the new
BTR Double springs
I will try to take a video and post it up for you guys, it definitely has a nice lope to it.
I appreciate all the help with the install guys couldn't have done it without your advice and guidance! Now just to get in scheduled in for a dyno tune. Currently running a mail order from PCM of NC.
