What could have caused this broken valve spring?
Old Jun 3, 2013 | 12:43 PM
THENASCAR's Avatar
The one thing that i notice is this. Every aftermarket spring i have used has a different lower spring seat and seal than that of a stock spring. The factory valve spring has the lower seat and seal combined which is what is still on your head from the picture, and they look old which means they werent replaced. It would not suprise me if those were stock springs. Any time you change a camshaft to anything other than factory. ALWAYS change to hardened pushrods and double springs. I never run anything without double springs. Aftermarket camshafts besides having increased lift and valve duration, also have increased ramp rates to achieve higher lift earlier, all of this is depending on the application. That is known as dropping a valve and it unfortunatly usually causes alot of damage. Your damage actually looks like it may be salvagable with a valvetrain replacement and head replacemnt. Good luck with your repairs. and i would suggest a new engine shop.And any reputable engine builder should have caught that, the machine shop just put the springs they were told to, most likely. Go through someone reputable.
Old Jun 3, 2013 | 12:53 PM
LSCha0s's Avatar
Ouch!! I lost a spring and was lucky it did not damage the head. Sorry about your misfortune. It's bad when we hire people to fail us then point the finger at one another.
Old Jun 3, 2013 | 08:54 PM
donnie_19's Avatar
From looking the valve springs assembly over more today, looks like the spring broke first. That let the valve float. Even is lock cam off the spring wouldn't break would it? There is a small gap between the locks but I don't know if that's in spec. Dropping the damaged head off tomorrow so Machine Shop can take more pictures to send to spring manufacturer. Any pictures of a correct lock assembly would be appreciated.
Old Jun 4, 2013 | 09:10 AM
TurboBuick6's Avatar
The gap in the locks is not my issue, that is normal. My issue is how far doen the locks are in the retainer. 9/10 times the locks should be flush with the top of the retainer. Do the locks come through the bottom of the retainer at all?
Old Jun 5, 2013 | 08:30 PM
donnie_19's Avatar
I will double check the locks in the morning. I am dropping a new head off tomorrow at the machine shop.
Old Jun 9, 2013 | 04:35 PM
donnie_19's Avatar
Default Spring ?
Here is a better picture of the valve spring assembly. They all look similar to this. There is a .060 shim under the spring.
I don't have a way to measure the install height but I will discuss this spec with the machine shop.
What springs should be used with this cam?
Attached Thumbnails What could have caused this broken valve spring?-corvette-lsx-valve-spring-assy.jpg
Old Jun 9, 2013 | 09:21 PM
DO NOT I repeat do not take those heads to who ever set them up the first time. Unless my eyes are going out your springs are installed upside down. Again I am 99% sure your locks are not fitting in your retainers as well.
Old Jun 9, 2013 | 09:33 PM
handyandy496's Avatar
tb6...U THE MAN
Old Jun 10, 2013 | 08:32 PM
squirlNUTZ's Avatar
DAMN! TurboBuick is correct. That's not correct.
Please post who is the engine builder ( butcher) and who assembled ( butcher) the heads.
I'm sorry sir but you have been robbed. Happens all the time though and it's a shame
Old Jun 10, 2013 | 09:47 PM
donnie_19's Avatar
Default How do you know correct orientation?
For my own information and others that read the forum are there marks on the springs that show what's the top and bottom? Same with the retainers? How do you know you have the correct retainers? Again what are the correct springs for this cam?
Old Jun 11, 2013 | 06:41 AM
The_Bishop's Avatar
They look to be beehive springs. With beehives, the narrow part of the spring is supposed to be on top.
The whole setup looks wrong, mismatched retainers, locks and springs.
Old Jun 11, 2013 | 07:36 AM
  #32
If it were my heads I would purchase new everything. Springs, retainers, seats (which are not on your head) and locks.
PAC-1218X(springs), PAC-R311(retainers), PAC-S111(seats) and PAC-L8114(locks).
Old Jun 11, 2013 | 07:50 AM
  #33
The_Bishop's Avatar
Or the Brian Tooley Racing package. They're damn good pieces.
Old Jun 11, 2013 | 08:13 AM
  #34
KCS's Avatar
KCS
Moderator
I had heard from an older racer that back in the day they used to run beehive springs way before anyone knew what we know about them today, but they ran them "upside down". The reasoning was that they could get more spring pressure from the larger OD while still fitting in the OEM 1.25" spring pocket. Unless you have been living under a rock, any competent machinist should now better nowadays.
Old Jun 11, 2013 | 03:20 PM
  #35
donnie_19's Avatar
This the the springs that I purchased, PBM3250 http://www.pbmperformance.com/store.php?catId=169. Since I didn't assemble how do I tell if these are the springs that are on the heads? Are there manufacture numbers or markings?
Old Jun 11, 2013 | 03:50 PM
  #36
no markings. have to measure dimensions and loads.
Old Jun 11, 2013 | 04:32 PM
  #37
Gray86hatch's Avatar
You need a new machine shop/assembler. screw me once your fault screw me twice my fault.
They used bare bones everything.
Also check the connecting rod to make sure it is not bent
Old Jun 17, 2013 | 12:11 PM
  #38
Any updates?
Old Jun 17, 2013 | 07:42 PM
  #39
3rdCoastPowerSports's Avatar
Schadenfreude, not totally but damn come on now
Old Jun 17, 2013 | 08:02 PM
  #40
donnie_19's Avatar
Any updates?
Stopped by machine shop and talked with owner tonight. All paper work and photo's have been sent to valve spring manufacturer to file a warranty claim. Will find out more info tomorrow.
This is the springs the machine shop used form PBM Performance. I have no way of verifying that these are the springs installed on my heads unless there is some kind of markings on the springs. Never once did I mention not to spend the money on using a good or better product.
This info taken from their web site. PBM 3250
The absolute BEST valve spring for the LS1 engine or SB Chevrolet.
•Conical design oval wire valve spring will fit factory retainer •Design delivers superior dampening
•Oval wire design allows higher valve lift & increased seat & nose pressures
•Ideal for hydraulic roller cam applications
Stock# INSTALLED PRESSURE OPEN PRESSURE COIL BIND MAX LIFT RETAINER Price Quantity
PBM3250
specs>> 110# @1.750"
