tech ? --valve position on an LS 5.3
Old Jun 5, 2013 | 01:34 PM
Lee Thompson's Avatar
Default tech ? --valve position on an LS 5.3
If I align the cam and crank dots face to face--what position will the valves be in ? (Exhaust closing and intake opening)
If I set both dots @ 12 o'clock (both valves closed--boom stroke)
Both of these positions has # 1 @ TDC
I assume this is correct---Thanks--Lee
Old Jun 5, 2013 | 06:18 PM
LS1MCSS's Avatar
12 and 12 is compression stroke.
12 and 6 is exhaust stroke, but it really doesn't matter which you use. The pcm will figure it out through the cam semsor.
Old Jun 5, 2013 | 06:35 PM
Default tech
Thank you--Lee
