How bad is it?
Old Jun 17, 2013 | 10:41 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Originally Posted by ThrelkeldsZ
How many hours of labor do you think the dealership would charge me just to torque down the heads and that's it?
These engines use TTY head bolts. You do not simply "torque down the heads and that's it"
This ain't no old school small block Chevy.
At a minimum, you'll need to pull the heads, clean everything up and re-install them with new head gaskets and head bolts. You *should* have the heads gone through to freshen them up.
Old Jun 17, 2013 | 10:43 PM
Paul Bell's Avatar
Well I have a book that tells me exactly how to do it so I may just do it myself like I was planning on doing
If you try to just torque down the heads, you'll snap some bolts and/or pull some threads and/or warp the heads.
Old Jun 17, 2013 | 10:45 PM
ThrelkeldsZ's Avatar
Yea I know you have to do the degrees and the correct pattern
Old Jun 17, 2013 | 10:46 PM
And I'm replacing all of the gaskets and bolts
