spun rod bearings, what needs replacing?
my question is what else should be replaced on my rebuild because of metal shavings getting in things, was going to do new lifters and oil pump then just wash the hell out of eveything else and do new main and rod bearings on rebuild.
anything else you all recommend doing or replacing?
will a reman crank from autozone be as strong as stock?
minus money would u say turning my crank be more reliable then what idget from autozone?
how would i get the whole assmebly balanced, i doubt it was
If you put a crank kit in it, I'm sure it will be fine for a while but IMO you will shorten the life of that new motor once all those metal pieces get moved around in your engine.
BTW, I agree with just getting your crank turned at a machine shop.
