Comp Cam with all lobes measuring different???
I am in the current process of putting a lot of money in this engine and really hesitant to reuse it, even when it has almost no wear. The engine builder is talking with Comp, but would like to get some other opinions so I know if they are blowing smoke up my a$$. Thanks for help and input.
Endless amounts of info on here and done quite a bit of searching, but have not seen any posts about lobes differing in size.
I did work with the machine shop to get the cam sent back to Comp Cams to have it CMMed and it came back out of Comp Cams tolerance. Comp Cams was willing to regrind the cam to make it right, but said I wouldn't notice the difference and that it normal for an catalog cam. I have deiced to not use any more Comp Cams products. I do give the props for admitting that the cam was out of spec though.
