Setting zero lash
Old Jul 10, 2013 | 09:41 PM
98ws6blk's Avatar
Default Setting zero lash
So I'm checking my pushrods length with a length checker. How tight against the rocker cup do you get the pushrod checker?
Old Jul 10, 2013 | 10:03 PM
wildcamaro's Avatar
Until it won't turn anymore...
Old Jul 10, 2013 | 10:05 PM
Burken01's Avatar
Till it touches but not pushing into the lifter...
Old Jul 11, 2013 | 08:03 AM
vettenuts's Avatar
I usually lift the rocker tip gently to reach this point, so there is no tick tick when you lift it. If you lift the rocker tip too hard though you can depress the lifter plunger so be careful when you do this.
Old Jul 11, 2013 | 08:11 AM
mark21742's Avatar
Just what vettenuts said, at tjis point you sould be able to lightly slide the rocker side to side....do it a few times and you will easily get the feel of it.
