what kinda revs?
Old Apr 29, 2004 | 01:50 AM
LordOfChaos's Avatar
Default what kinda revs?
I'm gonna have my cardynotuned perty soon.. I just bought it. its currently set with a rev limiter at 7000rpms. I'm not sure where i should be shifting at, I'mguessin at about 6800 based upon the dyno chart (402 rwhp, 400 rwhp at 6500 rpm) butI really dont know.
I am not very familiar with these motors, should I have my limiter bumped higherwhen I have the tune done, or am I already at about the max I want to be at?
Also... does someone have a link for me to where i can look at info on my GTP stage 2 heads? Who makes them? I did a search on the net, and all I foun was grand prix gtp stuff lol.
I appreciate the info.
Sorry for my ignorance, I'm new! I'm learnin
Old Apr 29, 2004 | 03:08 AM
Robzilla's Avatar
search for gtp on here and you'll get a lot more matches
Old Apr 29, 2004 | 04:18 AM
Nickn20's Avatar
gallant technical performance, thunder racing sells thier cylinder heads.
Old Apr 29, 2004 | 04:27 AM
kumar75150's Avatar
uhh we need a dyno chart to suggest where you should shift at
Old Apr 29, 2004 | 09:26 AM
DenzSS's Avatar
Something to keep in mind as well, these motors aren't designed to turn 7000 rpm in their stock form. You can for a while, but you'll eventually stretch/break a rod bolt or have other issues.
Also keep in mind that unless you're using a shiftlight, you're actually shifting 200-300 rpm higher than the tach shows. The tach has a low bus priority under WOT.
