? for the cam kings
Old Jul 16, 2013 | 05:49 AM
ITS-DVS's Avatar
Default ? for the cam kings
Hey guys.
Please don't shoot me for this cam ?
I'm currently building a burnout car. Need some help and opinions on the camshaft kit.
Ok so the engine is as follows:
Stock bottom end with ARP 2000 connecting rod bolts
Heads are stock 241 heads, besides the exhaust ports being matched ported.
Holley 2x4 Carb manifold, has 2x 600cfm vac secondary holley carbs.
MSD 6010 ignition controller
Turbo 400 and thinking of a 3,000rpm stall (Depending on what the cam needs. Not yet purchased)
1 3/4" 4 into 1 extractors with hi-flow cats straight out the sides of the car, So free flowing
I'm after a camshaft kit that has a very rough idle. Not fussed on fuel econ or anything as its a burnout car. I may take it down the strip once or twice to see what it runs down the quarter. But in reality it's not getting built for that.
Thanks for the help in advance. I would like to purchase a complete kit
Old Jul 16, 2013 | 09:44 AM
mark21742's Avatar
I ran a 238/242 for a while in my stock cube 04 gto. I ran a 4, 000 stall behind it.
Your burnout contests down under are completely different than ours lol I love your burnouts!
Old Jul 16, 2013 | 06:16 PM
garygnu's Avatar
check out Texas Speed or vengeance racing for good cam kits.
Old Jul 16, 2013 | 06:26 PM
JakeFusion's Avatar
Super Hulk Smash
TSP shipping internationally is really expensive.
I'm not sure who ships internationally without raping you though.
The stock cam should be plenty with TCS off...
Old Jul 16, 2013 | 06:32 PM
mark21742's Avatar
I'd do some local searching down there...with the following down there you should br able to find something
Old Jul 17, 2013 | 05:21 AM
ITS-DVS's Avatar
Thanks guys for your help. What cam spec would you guys recommend?
Old Jul 17, 2013 | 05:22 AM
ITS-DVS's Avatar
I should also ask, Who has ran a carby ls1, what spec was your cam and have you got any videos
Old Jul 17, 2013 | 01:54 PM
mark21742's Avatar
Most of the carb'd guys ive seen run a lot tighter lsa on their cams than the mpfi...more like a 108-109
