Best 1.8 rocker arms?
Old Jul 21, 2013 | 03:26 PM
Black00SS/65SS's Avatar
True but its something im goin to do and I can use them on my next build too
Old Jul 21, 2013 | 03:31 PM
HioSSilver's Avatar
Originally Posted by Black00SS/65SS
Preload was still good? So are you running the sharps now?
Yea still running them. Preload seemed fine. I didn't check it but nothing was obviously out. Could've maybe used a little shorter push rod but you would be splitting hairs. The valvetrain is quiet as stock.
Originally Posted by wildcamaro
So it was a ~5hp gain? The rockers cost the same as a cam...
Look at the results through the middle bud. As much as 10hp and 10 tq. That's across the board. Stock idle and well over 400hp. Pretty good imo. The closer you get everything optimized the harder they run too. There's always something some one could do to gain more power. But that was not my goal. Fine tuning what I have was my goal. There are plenty of cammed ls6's that don't make the power my stock cammed one does......figure that one out.
Old Jul 21, 2013 | 03:43 PM
davidws6's Avatar
Default H S Rockers
I've had 2 set's of 1.7 ratio and 1 set of 1.8 ratio for LS7 heads. NO Problems at ALL !
And the cam on the 1.8 heads had .645 lift ! Springs R stiff and all's good so far....
Old Jul 21, 2013 | 03:45 PM
Ok im goin to do the rockers with upgraded pushrods and a 10296 oil pump and put on my roll master timing set and figured id do bit all at once and I know what you mean friend of mine has an ls6 just bolt ons and hes at 400 whp too surprises alot of people
Old Jul 21, 2013 | 04:59 PM
99Bluz28's Avatar
FYI,
With the 1.8s you're looking at about .556" lift and with 1.85s about .571" lift.
Old Jul 21, 2013 | 05:08 PM
Yessir I just used the .030 number as a reference point but I appreciate it
Old Jul 21, 2013 | 05:13 PM
wildcamaro's Avatar
Not tryin to knock your set up bro, over 400 at the wheels with stock cam is good but in my book $300+ rockers=10hp and $400 cam=25-50hp...that's all I was trying to say...the reason people ask questions is to get opinions, so I gave mine...not trying to get in a pissing contest just saying what I think which is why this forum exists...
OP I see what ur saying to do rockers before you get a cam/heads setup installed..makes sense...
Old Jul 21, 2013 | 05:23 PM
KCS's Avatar
KCS
Moderator
You think a cam swap only costs $400?
Old Jul 21, 2013 | 05:26 PM
Yessir just goin through the valvetrain and just putting in stronger pieces. Ive always started with valvetrain as its really surprising to a lot of folks how much you lose due to deflection and loss of stability. We use to see it quite a bit on our spintron
Old Jul 21, 2013 | 05:32 PM
wildcamaro's Avatar
Yea those spintrons are pretty cool, def a useful tool
HioSSilver's Avatar
No pissing match to be had. My car runs 11.0 @ 131.xx n/a on a stock cam, stock drivability, great mpg's and a smooth idle. nuff said there. It's great you have a opinion, so does everyone else. Like I said there a allot of ls6's with cams that don't make what I do. In the end it comes down to attention to detail and shoving a cam in a engine is not always the right choice for someone.
Take op for instance. To put a replace the cam in his car to get any kind of gain he would probably need to go to a .600 lift cam or better. That would require a spring change for him and cost more. The rockers would require no spring for him and end up getting decent across the board results. You look at peak power to much. I'll take 10hp/10tq and 5 at peak any day over a cam that may actually lower tq and only give me 25-30 at peak.
Old Jul 21, 2013 | 05:34 PM
  #32
wildcamaro's Avatar
And no I don't think cam swap costs 400...but if your gonna do 1.8 rockers usually you have to do springs and pushrods just like a cam swap...so quick to try to jump on someone damn...
Old Jul 21, 2013 | 05:52 PM
  #33
Yes spintrons are very useful... springs and pushrods, timing chain and oil pump all to be upgraded at same time. Saving all the big goodies for a fresh engine.
Old Jul 21, 2013 | 05:53 PM
  #34
Definitely appreciate the feedback
Old Jul 21, 2013 | 07:30 PM
  #35
KCS's Avatar
KCS
Moderator
Not necessarily. You can keep the stock springs and pushrods with a lot of the stock cams. The swap would take maybe 30 minutes. Not so much with the majority of the aftermarket shelf cams. You swap a cam and you're replacing gaskets, crank bolt, probably a retainer plate too. Most people will get a case of the "while I'm at it" and swap the timing chain and oil pump. Now you're running the risk of pinching an o-ring or not centering the oil pump correctly.
This isn't even considering someone who would take it in to have a shop do the work. Take the labor into consideration and the rocker swap becomes a very attractive option.
Old Jul 23, 2013 | 07:33 AM
  #36
2000ultraZ1911's Avatar
Anyone have trouble with Harland Sharps? Buddy has a 01 vette with 241s and they didn't fit...he went for the jegs which did fit but no seat of ur pants power he was pretty un happy th em for the money he spent.
Old Jul 23, 2013 | 07:38 AM
  #37
But real world I've seen the Harland sharps not fit...and he was un happy with jegs...drove wildcamaros Z with the cam and you can't even compare the two apples and Oranges but I guess its all in what ur looking to gain which won't be much with rockers.
Old Jul 24, 2013 | 11:43 AM
  #38
HioSSilver's Avatar
I have not had any trouble with Harland Sharp rockers. They been on my car for years.
With that said I have seen broken ones. But that car had alot of spring on it. I run beehives with no issue.
Old Jul 27, 2015 | 01:00 AM
  #39
stage274's Avatar
Originally Posted by HioSSilver
Here ya go. Had some pretty good gains threw the middle.
Your car so rocks... Extremely impressive for a crate motor. I want to do these rocker change, I am running a stock 383 ls6 set up, 5 lbs with a p1sc on it.
Soon with a f1a going on. The motor dynoed 454 hp and 494 ftlbs on 9.0 compression. That was with a 750 carb on the dyno. I am sure now the motor has broken in, that I have more power now. It feels a lot faster. But god damn, your car is flying for a ls6 347. It goes to show you, what years of tunning does. I am sure I will pick up 20 to 30 hp by running these rockers. Speedmaster looks like a nice set. I don't want to change the cam. I love the ls6 cam, but I know I should have more lift. I love the drivability also, the car is so quiet, so docile, untill I hit it. I like it like that. Your car is a sleeper that's for sure. Just wow!
