Oil recommendations?
Old Jul 22, 2013 | 10:54 PM
Joemac5959's Avatar
Default Oil recommendations?
I am doing a cam/intake/nitrous on my 50k mile ls1. What is the best oil and filter to run?
Old Jul 22, 2013 | 11:18 PM
JakeFusion's Avatar
Super Hulk Smash
Valvoline VR1 10W30 Conventional Oil and Wix 51522 Oil Filter for the trucks. It's a little taller and holds/filters more oil.
That's what I run and recommend to anyone who has an upgraded valvetrain.
Old Jul 22, 2013 | 11:30 PM
badassracing's Avatar
^^^ +1. Can't go wrong with Valvoline vr1. We use Brad Penn Grade 1 5w30 partial synthetic to give a little more protection on cold starts but either would be a good choice as long as you're not running cats.
Old Jul 22, 2013 | 11:53 PM
mcdonald77's Avatar
What about the German Castrol?
Old Jul 23, 2013 | 12:08 AM
JakeFusion's Avatar
Super Hulk Smash
I run German Castrol in all my other cars. For a stock LS1, it's more than enough.
It conforms to the SL rating, not the newer SI rating. SL allowed for more ZDDP type additives, which the EPA deemed bad since it ruins catalytic converters... after like 100k miles.
VR1 I believe loosely conforms to SI, but since it's an "off-road use" race oil, Valvoline puts lots of anti-wear addictive in there. You can get the NSL version, but it has no detergents and doesn't really provide additional protection. So you have to change your oil every 500 miles or so. Conventional VR1 oil is about every 3k. The synthetic provides no additional benefits, but costs twice as much.
Btw, two things to look for in an oil are anti-wear and cushion. This is especially important on bearings that see a high load or valvetrain items like rocker arms or cam lobes that see direct loads. Oil acts as a shock absorber in this instances as the loads aren't trying to sheer the oil apart like a piston riding up and down the cylinder.
So, you want oil that has extremely high anti-sheer properties as well as high-levels of cushion. The VR1 oils are always near the tops of those types of tests.
Old Jul 23, 2013 | 01:03 AM
Decadence75's Avatar
Unfortunately if you ask this question a thousand times you will get a thousand answers. My advice would be to spend some time on bob is the oil guy and decide for yourself. I jumped on the Mobil1 train when I first joined here but have since moved to shell rotella t 15w40 and a purlator filter. It is all a personal choice about the tolerances you want to see in the engine. Just look at the data and come to your own informed decision.
Old Jul 23, 2013 | 02:52 AM
TheWolfMatt's Avatar
Not this again!!!
Old Jul 23, 2013 | 05:02 AM
DACTARI's Avatar
When it is said tht high ZDDP oils "ruin" cats, what does that mean exactly? Do they just inhibit their ability to catalyze chemical reactions or do thu actually clog them up. The former would be tolerable but the latter could lead to a performance deficit.
Old Jul 23, 2013 | 05:28 AM
crainholio's Avatar
API increments the ratings in alphabetical order.
SL
SM
SN
Old Jul 23, 2013 | 06:03 AM
dhctss's Avatar
I use mobile 1 ow-40 european formula. It meets hgher standards for a true synthetic. I like it and seem to have less oil consumption then pennzoil platnium I was using before
Old Jul 23, 2013 | 07:10 AM
BrntWS6's Avatar
Originally Posted by DACTARI
When it is said tht high ZDDP oils "ruin" cats, what doe. that mean exactly? Do they just inhibit their ability to catalyze chemical reactions or do thu actually clog them up. The former would be tolerable but the latter could lead to a performance deficit.
"Ruin" is an exaggeration.... The VR1 oil conforms to standards common in the 90's. I think cats were rated for 80k miles or so back then...I can't remember exactly.
Old Jul 23, 2013 | 07:54 AM
JakeFusion's Avatar
Super Hulk Smash
It is the SM rating. And it sucks.
Old Jul 23, 2013 | 08:03 AM
BigBirdLS1's Avatar
I use Castro Edge 10w 30 (gold bottle) my valve train seems to be quieter with this oil. I've tried all the other of the shelf full synthetics and they perform great, but have a noisier valve train.
In short OP you can't go wrong with a quality synthetic with a quality filter.
Old Jul 23, 2013 | 09:36 AM
Joemac5959's Avatar
I've been told to use this or the mobile 1. Wix has always been the filter of choice for me.
10w30 the best??
Old Jul 23, 2013 | 09:55 AM
JakeFusion's Avatar
Super Hulk Smash
10W30 is the best VR1 oil.
Mobil 1 5W30 is pretty thin. Most folks notice a bump in oil pressure when switching to a thicker oil, like the German Castrol 0W30 or VR1. But M1 is a good oil.
Old Jul 23, 2013 | 11:43 AM
conan's Avatar
Silver bottle Valvoline - VR1 10w-30 with a NAPA 1522 filter or a delco PF61, both are the tall style filter.
Old Jul 23, 2013 | 12:12 PM
DACTARI's Avatar
I realize it's an exaggeration, which is why I put it in quotes. So, do the cats get clogged up or is it simply that their ability to catalyze reactions is diminished?
Old Jul 24, 2013 | 03:41 PM
BrntWS6's Avatar
From my understanding the phosphorous and zinc can poison the catalyst but won't clog it.
Old Jul 24, 2013 | 03:45 PM
senicalj4579's Avatar
I also use the m1 0w40. It also has a higher ZDDP content than most off the shelf oils.
Old Jul 24, 2013 | 05:55 PM
squirlNUTZ's Avatar
5w30 (synthetic ) and wix or purolator filter. The only damn thing I buy from Wally World is oil and filter.
