Stock bottomend HP rating?
Old Jul 28, 2013 | 08:19 AM
DisasterpeaceWS6's Avatar
Originally Posted by mark21742
But just remember once you get use to it again you will want to crank the boost up to make more power.
Will it hold, yes it should, but I'd build my bottom end up first so it could take anything I throw at it later
Will my LS1 bottom end be able to handle same as the LS6?
Old Jul 29, 2013 | 06:21 AM
mark21742's Avatar
Should be able to...the ls6 block is made with a slightly different alloy and has slightly better oiling
Old Jul 29, 2013 | 07:26 AM
Sweet!
Old Jul 31, 2013 | 02:29 PM
Forcefed86's Avatar
Not a matter of the stock bottom end holding the power. It's a matter of using good enough fuel and tuning to keep the motor out of detonation. I run a 100% OEM bottom end 5.3 (the "weak" older engine 2001) including all OEM 160K+ hardware/bearings etc.
I run 20+psi throu an s400 (75mm) turbo and make around 700whp. Plan on turning it up too. Using E85 out of the pump. (around 70% ethanol)
