408 LTFT help?
Old Jul 29, 2013 | 09:01 AM
408-99-f's Avatar
Default 408 LTFT help?
I hope I have this post on the right forum. I have a fully forged 408 tfs 215, 247/251 623 111 lsa, fast 90/90 my fuel trims will be at 10% thrn jump to 20% back and forth. It was tuned at rpm in DEL. WHY I don't have any vacuum leaks
Old Jul 29, 2013 | 09:19 AM
TheWolfMatt's Avatar
Did you change injectors when you did the intake/cam swap?? Either way you look at it, the engine needs to be tuned before you run it, could cause damage if it isn't tuned beforehand.
Old Jul 29, 2013 | 11:19 AM
408-99-f's Avatar
Its tuned by rpm (Race proven motorsports) and has 42lbs injectors. I smoke tested it and went over every vacuum port. Ie booster pcv intake ect ect
