Ticking noise after cam install
Does sound like a bad oil pump o ring to anybody? I replaced the oil pump during the swap and re-used to o ring since the pump didn't come with one. At cold start up I have 60 psi at idle and when it gets warm I have anywhere from 30-40 psi.
This what mine did when it was the oil pump oring. I replace it and the pump and problem went away. Maybe you pinched it when you went together with it?
