Timing Chain Question
Old Aug 16, 2013 | 10:13 PM
Bama99z's Avatar
Default Timing Chain Question
Ok here is my question. I am building a little 408, however I have purchased a new GM LS2 timing Chain ( 12586482 ) Camshaft Sprocket ( 12576407 )
and a new Crankshaft Sprocket ( 12556582 ). Is this set up going to be ok? Or do I need to order a aftermarket one? What is your thoughts?
Old Aug 17, 2013 | 04:58 AM
ls1 1990 VN's Avatar
End of the day it's your call due to what you will be using the car for.
You will normally be good to go, if you are doubtful then fit a LS2 damper with it.
If the blocks not tapped then use the Trick Flow damper adapter.
Old Aug 17, 2013 | 06:04 AM
Decadence75's Avatar
Street driven with the occassional track pass, then you should be fine with the LS2 chain.
Old Aug 17, 2013 | 06:39 AM
vettenuts's Avatar
The timing chain damper, as mentioned above, is more important than the chain type. The LS2 chain should be plenty strong enough but it can still suffer from block harmonics and chain wrap. The best setup with the parts you have would be to install the timing chain damper and a good harmonic damper (pulley). Spend the money on an ATI harmonic damper. Harmonic dampers are responsible for a some of the timing chain failures that are blamed on the chain itself.
Old Aug 17, 2013 | 06:51 AM
In my opinion, unless the motor will be road raced with rpms in the constant higher ranges that will see excess vibrations on the timing system, an expensive pulley like ATI is un-necessary. Since the LS crank is internally balanced most applications would be fine with any aftermarket pulley.
Old Aug 20, 2013 | 05:54 PM
Bama99z's Avatar
Decisions,Decisions,Decisions, I will br going witn an aftermarket Harmonic Balancer. Just havent decided on which one yet.
Old Aug 20, 2013 | 06:14 PM
Burken01's Avatar
ATI is the way to go, the heavier steel one will be perfect.
The Ud pulley is not something I would cheap out on..
Old Aug 20, 2013 | 06:30 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The ATI is awesome and is never a bad idea. It's not necessary for most of us who just drive our cars on the street and drag race though. The Powerbond fits the bill for most of us. Road racers and their extended intervals of sustained RPM definitely benefit from an ATI.
If I can help you out on either one just let me know! You'll find the powerbond in my signature, and if you mention i nthe comments that Jesse sent you from the forum we will remove the shipping charge from your order when we process it. You can call me to discuss your needs if you'd like, and we'll point you toward whichever balancer meets your needs the best and try to cut you a deal on whatever you choose.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 20, 2013 | 07:12 PM
wildcamaro's Avatar
You'll be fine...
Old Aug 22, 2013 | 09:44 PM
Bama99z's Avatar
Guys, thanks for all of your input. Looks like I'm going to go with it.
