Need help finding tools...
Old Aug 17, 2013 | 01:23 PM
QuadratSS's Avatar
Default Need help finding tools...
i'm getting ready for my in car cam swap on my 02' SS. I need to purchase two tools for the job.
Looking for
1 JPR cam install tool to hold the lifters
2 MORE valve spring compressor that fits under the cowl
Was told i could get them from thunder racing, but is seams as tho they have closed. anyone know where i can get the proper tools that i need?
Old Aug 17, 2013 | 01:27 PM
00Vette04GTO's Avatar
http://www.summitracing.com has just about everything - shipped to your door. Big company like JEGS.
Old Aug 17, 2013 | 01:34 PM
badazz81z28's Avatar
Looking for
You should be able to get away without the lifter tool. That is unless your trays are very worn.
Old Aug 17, 2013 | 01:43 PM
QuadratSS's Avatar
shouldn't be that worn car only has 26k on it, but i dont like the term "should be" I dont want to take any chances
Old Aug 17, 2013 | 02:20 PM
Agree, but risk is low. By rotating the cam without the rockers and push-rods, they will be captured in the lifter trays and stay put. Not guaranteed like you said based on wear, but most of the time it works.
Old Aug 17, 2013 | 04:40 PM
redbird555's Avatar
i wouldnt waste money on the cam install tool. the lifter trays should hold up fine however go to lowes or home depot and get a 5/16 wooden dowl and cut it to length then file one end down to round it off. works just like the metal tool but only costs 75 cents
Old Aug 17, 2013 | 05:25 PM
Orry Bynum's Avatar
This!! Or you can get some magnets and a couple of friends lol not recommended..... Btw how long do the wooden dowls have to be?
Old Aug 17, 2013 | 05:34 PM
87silverbullet's Avatar
They have to be the length of the motor.
OP, I have done some pretty high mileage motors and the lifters stay up with no issues.
Old Aug 17, 2013 | 05:38 PM
Orry Bynum's Avatar
How long is the motor?
Old Aug 17, 2013 | 05:41 PM
3rdCoastPowerSports's Avatar
Thats what she said
Old Aug 17, 2013 | 07:14 PM
LS1MCSS's Avatar
If they were 6" longer than the cam, that should be plenty. If you don't have the new cam yet, to measure off of, then you have plenty of time to go get the dowl rods.
Old Aug 17, 2013 | 09:39 PM
QuadratSS's Avatar
good idea with the wooden dowls! I would have never thought of that. Anyone know where to get the MORE valve spring compression tool?
Old Aug 18, 2013 | 10:57 AM
vettenuts's Avatar
Don't know about the More tool, but Vinci designed the Crane valve spring compressor and still sells it. Here is a link. Best tool I have ever used for this with the heads on the car. Link to Vinci Valve Spring Tool
Old Aug 18, 2013 | 11:55 AM
If you make them about 3 inches longer than your valve cover you should be good
Old Aug 18, 2013 | 06:41 PM
QuadratSS's Avatar
thank you for the link to the vinci tool. tool is very short. looks like it would fit under there no problem
