Cracks on 706 heads?
Old Aug 18, 2013 | 12:14 AM
Shortbed70's Avatar
Default Cracks on 706 heads?
So has anybody had this problem? If so where do they crack and how prone are the 706 castings compared to others??? I'm trying to budget build a motor and then I hear about the heads could crack...
Old Aug 18, 2013 | 12:15 AM
Shortbed70's Avatar
Btw they are off an 04 5.3
Old Aug 18, 2013 | 12:31 PM
Shortbed70's Avatar
Anyone???
Old Aug 18, 2013 | 05:51 PM
KCS's Avatar
KCS
Moderator
It's common, I think they tend to crack around the head bolt flanges and leak water. Look for the battery logo cast into the heads on top of the port.
Old Aug 18, 2013 | 05:53 PM
Burken01's Avatar
Never heard of 706 castings cracking, where did you get this info?
If they cracked maybe the installer over torqued the head bolts???
Old Aug 18, 2013 | 06:02 PM
Shortbed70's Avatar
I've heard this from several people including a guy that builds some nasty ls engines around me...
Old Aug 18, 2013 | 06:03 PM
Burken01's Avatar
^^ interesting never heard of that
Old Aug 18, 2013 | 06:41 PM
squirlNUTZ's Avatar
The 2006 ( call Scoggin Dickey to confirm) are the model year that had issues. Something to do with the tooling. The cores to be exact. With that said I have used a few sets with no issue, but a set of lingenfelter heads came threw a friends shop and was pushing water on the engine. My friend pressure tested the heads and found no issue, so back on the engine they want with new gaskets. With in a couple weeks they where back with a very upset customer. With a further examination of the head they were found to be cracked at the bolt hole.
GM did have a service bulletin about these heads that have the battery emblem ( investment cast I think). Not all heads with this emblem are bad only the truck heads of 2006 and only some. It is a crap shoot if you'll have problems but agin it was only one year and I can't find my GM bulletin I had.
Hope this helps
Old Aug 19, 2013 | 09:15 AM
Shortbed70's Avatar
Well I'm going to run them as the truck didn't have any coolant issues ad I'm cheap...found head gaskets MLS for $46 from my ls guy.. Ordering tonight!
Old Aug 19, 2013 | 01:56 PM
chrisfrost's Avatar
From what I understand it could happen to any 706's that were made @ Castech which has a logo on top of 1 of the ports. The logo is a C with something in the middle or something like that . I know the C is easily identifiable .
Old Aug 19, 2013 | 08:43 PM
Russ K's Avatar
This is the head in question.
If the cylinder head(s) is a Castech casting (1), inspect the area around the five oil drain holes for witness marks indicating coolant seepage over time (2).
If No evidence of coolant loss is found on inspection of Castech casting cylinder head(s), follow normal diagnostic procedures in SI to determine the cause of the coolant loss.
Russ Kemp
Old Aug 19, 2013 | 08:58 PM
Shortbed70's Avatar
My 706's have the AA battery looking mark so guess I should be worried? The truck had no issues before...
Old Aug 19, 2013 | 09:31 PM
Shortbed70's Avatar
I did notice one of the heads have a fairly large casting line that runs under that bolt area but what would coolant sepage look like? I know the oil would be milky but it was not!
Old Aug 20, 2013 | 06:46 PM
k24556's Avatar
Default Castrch heads
See if this link helps. This explains the problem and where to look.
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
Old Aug 20, 2013 | 08:08 PM
Shortbed70's Avatar
So where does the water go if it gets into the oil? Every motor I've had that got water in the oil turned into a milkshake?
Old Aug 20, 2013 | 08:15 PM
rnl35thss's Avatar
I've seen a couple pick ups with this problem. There was signs of water when doing oil changes. Oil extra nasty with chunks, even at regular intervals. Wasn't like milkshakes on the ones I saw, but you could definitely tell something was up.
Old Aug 20, 2013 | 08:18 PM
Shortbed70's Avatar
There's been no sign of water and wasn't any sign when it was pulled... In the oil
Old Aug 21, 2013 | 06:33 AM
k24556's Avatar
Well, my '04 5.3 truck has castech heads, 90k miles, and there has never been a sign of water in the oil, but like your experience, the water looks like a milkshake in those cases where coolant gets in the oil.
So, like the bulletin says not every castech head, but they were the only heads that had the problem. YOu may not have a problem even with castech heads.
Old Aug 21, 2013 | 02:58 PM
Birdracing's Avatar
I have a 5.3 litre also with the 706 heads I got the heads off the motor now, I checked the topans looks good, I halled the basepan off last night there isn't no signs of coolant in the oil.I also have the battery logo on the head, I am going to send the heads off to the machine shop to get checked I guess..
Old Aug 21, 2013 | 10:45 PM
Shortbed70's Avatar
Call me crazy but since they didn't have any issues before I took apart I'm gonna run them...
