Help with catch can loaction
Old Aug 18, 2013 | 01:21 AM
VRSenator065's Avatar
Default Help with catch can loaction
Hi All, apologies up front, as I am pretty sure I have read a dedicated thread on this but I just don't seem to be able to find it. So feel free to answer if you can or point out a link to where I should post this?
I am wanting to fit and plumb an oil breather catch can to my LSx454. I am running a Meziere electric water pump. I think the spot that would work is between the pump and the head. Has anyone got any ideas on what brand or make to go for, and if that's a good spot or not, and what i should look out for (if anything)
Thanks
Old Aug 18, 2013 | 06:17 AM
SOHCNightmare's Avatar
I'm sure you could make a small bracket out of some angle aluminum and use those bolt holes facing the front of the car on the heads.
Old Aug 18, 2013 | 06:56 AM
Old Geezer's Avatar
Maybe try the external engine forum??
Old Aug 18, 2013 | 06:23 PM
99Bluz28's Avatar
I'd mount it up front on the passenger side of the engine compartment(high or low), this will allow the CC to trap more oil vapor regardless of brand.
