Difference between 243 & 799 heads
Old Aug 21, 2013 | 11:33 AM
wildcamaro's Avatar
The thinner head gaskets will give a minimal increase in compression and they are pretty pricey at around $100 a pair for the cometics...depending on machine shop charges usually it would be cheaper to mill heads 0.030 or 0.040" and you pick up substantial compression around like half a point or more..
Old Aug 21, 2013 | 11:39 AM
Apocolipse's Avatar
its basically 0.013" difference between the gaskets which is not a TON but should allow better quench. Now, doing BOTH would be best of both worlds.
Old Aug 21, 2013 | 07:18 PM
wildcamaro's Avatar
No doubt...just cheaper to mill, them cometics are expensive
Old Aug 21, 2013 | 08:32 PM
intenseblue's Avatar
While the benefits are minimal for either, a .040 gasket will increase compression around .3 and provide a better quench which is beneficial. Milling plus mls gaskets will probably be more expensive than cometics plus milling reduduces flow and can increase valve shrouding. I reccomend both, but fact is fact if its one or the other the thinner gasket is the better option.
Old Aug 21, 2013 | 10:32 PM
Apocolipse's Avatar
Even at a 10 or 20 thou its going to make THAT big of a difference on fill? High lift or low lift scenario?
Old Aug 22, 2013 | 08:42 AM
wildcamaro's Avatar
An .030" mill isn't going to be enough to shroud the valves to the extent your talking, a stock head gasket is 0.050, so picking up 10 on the head gasket doesn't have near the benefit of compression increase of 3 times that with mill, I didn't think the milling was that much $$...
Old Aug 22, 2013 | 08:55 AM
Apocolipse's Avatar
Milling isn't much $. I just wanted a reliable 11:1 that I do not have to worry about detonating on 91 oct which is why I wanted the thinner gasket to increase quench.
Old Aug 22, 2013 | 08:56 AM
Roarin_8's Avatar
What would milling the heads cost about roughly? If it's $50 and MLS gaskets are around $50 it would be cheaper to go just the cometic gasket route which are anywhere from $85 to $103 depending on bore size.
Let me edit that, those prices for cometics are for 1 only!! So $85-$103 each. http://www.texas-speed.com/p-2258-co...3910-bore.aspx
Old Aug 22, 2013 | 09:18 AM
RonSSNova's Avatar
Remember the pistons are out of the hole about .007-.008".
I think .035" quench is safe. Kind of leaves you with the .045" gasket, and they are spendy.
On 91, I'd concentrate on quench first, CR second.
Just my opinion.
ron
Old Aug 22, 2013 | 10:11 AM
Apocolipse's Avatar
I don't mind spending money on gaskets. It is cheaper than chunking a piston and doing a rebuild due to detonation. I value your opinion for sure.
Even a small mill on the head would be a good idea to get the cometic to seal properly. But.. what about the block finish? Will I have to get that decked with a cometic? Or just get some copper spray?
Old Aug 22, 2013 | 10:15 AM
TransAmcoupe98's Avatar
Originally Posted by Bad28
Just like the title says what are the differences I know that they are basically the same head but what is the difference
90 whp...
Old Aug 22, 2013 | 02:26 PM
  #32
.030 is good on these engines.
Old Aug 23, 2013 | 03:54 PM
  #33
Apocolipse's Avatar
It looks like cometic offers thinner gaskets even... 0.027"
http://www.jegs.com/i/Cometic-Gasket...ductId=2848860
Maybe a bit too much quench?
To the poster above, 0.030 total quench?
So since the pistons come out about 7 thou, can run the 0.036 gasket and be around 30 like you say...
Old Aug 23, 2013 | 07:42 PM
  #34
PREDATOR-Z's Avatar
If this is street then .03x is the tightest I would go.
Old Aug 24, 2013 | 11:26 PM
  #35
Apocolipse's Avatar
Yup street car. Ill measure how much it comes outs hole. Seems usually 7 thou. 41 gasket @ 7 thou is 34... 36 puts me at 29...
