stock crank
Old Aug 18, 2013 | 10:09 PM
red 04 goat's Avatar
Default stock crank
im looking to go to forged pistons and forged rods ... what is the horsepower rating on the stock crank?
Old Aug 18, 2013 | 11:11 PM
conan's Avatar
People have made 1,000+ hp on a stock crank. What plans do you have for this engine?
Old Aug 19, 2013 | 11:33 AM
my plans are for about 600 hp... with some boost.. i just got done installing a cam and header.
Old Aug 19, 2013 | 01:33 PM
chrisfrost's Avatar
From everything I've read in LS1 Tech gen3/4 internal engine 4 the last 4 years the main issue is how high You push the rpm's . At 400-1000+ HP without forged rods & crank (rods being the weaker of the 2) You can safely run to 6500+ all day long as long as You're set up is stock or rebuilt correctly . Now having said that I'm reminded of a thread in this forum about a year maybe a year n a half ago where a guy said that the factory oil pumps pressure drops off like a rock above 6500RPM's and the melling high vol pumps were good to 8000rpm's
Old Aug 19, 2013 | 01:40 PM
AES Racing's Avatar
We have made over 1100 under the tire with a stock crankshaft....
Old Aug 19, 2013 | 06:16 PM
conan's Avatar
You'll be just fine at that power level with a stock crank.
