Rear Crank Seal???
When I did the instal I put the seal in the rear cover first and then just put in all on. I just thought the seal ring looks a little akward pointing out like it is. It is still making good contact on the side of the crank and is not interfering the the flex plate/flywheel mounting surface.
Thoughts?
Cheers
Bret
If you are worried about it post a pic, but If you use google to search you will find plenty of ls1 rear main seal pics.
Thoughts?
Cheers
Bret
Thanks for the input
Russ Kemp
