Running bad
Old Aug 24, 2013 | 04:53 PM
ridndirty1000's Avatar
Default Running bad
Hello,
I bought a 228r cam 7.425 push rods ls2 timing chain and double springs from texas speed. I am not sure what went wrong as the install went smooth and I lined the dot on the cam sprocket and crank up what looked really straight up and down. the car seems to idle perfect and revs good but when I drive it feels like it is missing, but the only code that comes up is P0425 which comes up as a fuel problem I just got the computer back from Frost which I called and they were really helpful but still not sure they said bad gas but it never ran like that before if you step on the throttle you can hear it like a ticking sounds like its missing but again no code comes up other than the P0425. car idles at 825 perfect and revs up all the way with no stutter or nothing.
Old Aug 24, 2013 | 07:42 PM
could it be like a bad plug wire?
Old Aug 25, 2013 | 05:55 AM
ryridesmotox's Avatar
How loud is it? Could be a lifter... If you scratched or otherwise marred a cam bearing you could be experiencing an oil pressure issue... which could cause issues for a lifter (or multiple lifters). Hydraulic lifters need oil pressure to work right.
Old Aug 25, 2013 | 06:17 AM
HMM well I have a ls6 ported oil pump and the oil pressure is at like 65 70 then when reved it goes almost to 80
Old Aug 25, 2013 | 06:30 AM
there is a little lifter tick but not to loud....I have def heard alot worse. if I remember right even the factory ones have that little tick with them.... I just bought some msd wires so I will see if that will take care of the problem....
Old Aug 25, 2013 | 06:48 AM
02 reaper z28's Avatar
I would start from the small to big and usually is the small stuff you miss that's going to be your problem. like check plugs, wires , coils, then move up to rocker arms, push-rods, etc..
Old Aug 25, 2013 | 06:51 AM
I am hoping for the wires I put new ngktr55 but kept the old wires and you know when you pull them damn things out it isnt the easiest thing to do so hoping I just messed up a wire it sounds like a miss so we will see.
