Rebuild question
Old Sep 4, 2013 | 12:56 PM
chevybayboy's Avatar
Default Rebuild question
OK getting my 383 put back together, I know on first start up I prime the engine but since I'm going from 347 to 383 and bigger injectors do I need my pcm flashed first before I start car or do i tow it to tuner for the flash first?
Old Sep 4, 2013 | 02:20 PM
2000PewterT/A's Avatar
It should run, not good but it should, I would want a tune before I drove it anywhere.
Old Sep 4, 2013 | 04:05 PM
Gunslinger09's Avatar
Yep.
I would start it just to check for leaks but not put ANY load on it to include free rev. And shut it off as soon as you know there are no problems.
Old Sep 4, 2013 | 05:46 PM
k thanks fellas
Old Sep 5, 2013 | 03:07 PM
schnellttz06's Avatar
The bigger injectors are gonna create more of a problem than the added displacement. You should run it with the stock injectors until you get to a tuner or you will damage your engine.
