Misfire - only at start-up
Old Sep 6, 2013 | 09:17 AM
Asim's Avatar
Default Misfire - only at start-up
Hey guys,
Have a misfire, only for the first 2/3 minutes after starting the car. Funny enough, its everytime I start the car, not just when its cold.
I can drive it for a bit. Turn it off and back on and it will mis again until I start driving.
Just started last week.
Any help is appreciated.
Asim
Old Sep 7, 2013 | 04:26 AM
01ssreda4's Avatar
Could be a head gasket or leaky injector. Coolant, or gas, drips into the cylinder while the motor sits and causes a miss until it burns it off. Very common symptom.
Old Sep 7, 2013 | 10:11 PM
oerllikon's Avatar
Had this problem with my XJ. Some lucas injector cleaner and WOT fixed it. Im guessing it was the injector. YMMV
Old Sep 7, 2013 | 10:21 PM
MyFirstLS1's Avatar
a leaking injector would also cause a long crank as well, if that helps aid in diagnosis. You can pull the plugs and check for a fuel fouled plug. Should smell like fuel or be very black
When you shut it off/ and restart warm is it still for 2/3 minutes ?
Trying to figure if it goes away once it goes into closed loop
