Oil cooler?
Old May 3, 2004 | 10:53 AM
ulySSes's Avatar
Question Oil cooler?
I picked up an issue of Super Chevy Magazine yesterday and read an article on how to keep the oil on your LS1 cooler? Is this procedure a good idea? I always thought '01-'02 f-cars already had engine oil coolers. True or false?
Ulysses
Old May 3, 2004 | 02:19 PM
robertbartsch's Avatar
Na.... engine oil coolers are interesting but not really needed for the street...
Old May 3, 2004 | 05:36 PM
Sniper33's Avatar
I have an engine oil temp gauge installed on my '02 Z and so far I haven't seen anything over 240*. The times I've seen it that high were when I was driving it really hard, really fast, and lots of high RPM's. Once you calm down, the temp goes down pretty fast. The car is a daily and sees the strip often in the summer. I don't see the need for it, at least in my application.
Old May 4, 2004 | 06:52 AM
kossuth's Avatar
If you road race alot then it is needed. What I recommend for you is contact Valvegod. You can use a truck oil cooler setup with a slight amount of modification. Basically that block off plate above the oil filter is where it bolts to. Talk to him he can give you all the info you need. On the street it isn't really needed.
