PTV Clearance with new cam
Old Sep 17, 2013 | 05:16 PM
455GTO's Avatar
Default PTV Clearance with new cam
Wondering if the following set up will cause any PTV issues.
2002 Pontiac Trans AM-LS1
My current cam set up is:
232/234 114lsa (Torquer v2)
63cc A.I. ls6 heads
.040 cometic head gasket
11.1:1 static and 8.2:1 dynamic
New cam specs:
235/242 113+2
.620"/.610" @50
Almost the same compression
Any experts out there know if I will have enough clearance?
Old Sep 18, 2013 | 05:24 PM
Bama99z's Avatar
63cc A.I. ls6 heads
New cam specs:
235/242 113+2
.620"/.610" @50
Cam was originally spec'd out for a 5.7 with a set of Patriot Performance stage 2 59cc heads. I was told by the head as well as the cam manufactures that with factory thick head gaskets that everything would be fine. But I never installed it so I am not 100% sure.
Old Sep 18, 2013 | 07:08 PM
mchicia1's Avatar
11:1 and a cometic?
I would say most definitely not, you definitely need to measure it.
Old Sep 18, 2013 | 07:42 PM
badassracing's Avatar
The 111 ICL will help with clearance. You wont know for sure until you put it in and measure it though.
Old Sep 18, 2013 | 07:48 PM
Bama99z's Avatar
Always check valve to piston clearance no matter what the manufacture says.
Just my .02
