Stock cam and .660 springs?
Old Sep 21, 2013 | 11:00 PM
Asian LSX's Avatar
Default Stock cam and .660 springs?
I've got a cam and some BTR .660 springs and was wondering if I could change out the springs first and still drive the car like that until I get the time to get a tune and swap the cam. Will it hurt anything running .660 springs and a stock LS1 cam?
Old Sep 21, 2013 | 11:35 PM
Boostedhatch's Avatar
Should be good wouldnt see any problems.
Old Sep 22, 2013 | 12:39 AM
silverz28camaro's Avatar
Your good, I have .675 springs with a stock LS6 cam....works great for boost and 7,000+ rpm, My buddy did the ls6 yellow springs on a stock can and pickup up a few mph at the track, he was shifting high, like 6,400 on a stock engine and the added spring spresure over stock ls1 springs really helped with valve control
Old Sep 22, 2013 | 11:54 AM
KCS's Avatar
KCS
Moderator
It will be fine, assuming the springs are installed correctly.
Old Sep 22, 2013 | 04:44 PM
Asian LSX's Avatar
Thanks or the info. This will make my cam swap process alot easier to plan out.
Old Sep 24, 2013 | 03:02 PM
chrisfrost's Avatar
The only thing to note here is that stiffer springs will wear the valve train a little quicker but that should be fairly obvious
Old Sep 24, 2013 | 03:49 PM
KCS's Avatar
KCS
Moderator
Doubt it.
