4.8 build help
Old Sep 30, 2013 | 11:20 PM
06crewcab4.8's Avatar
Default 4.8 build help
Hey guys how's it goin! I've got a 2006 silverado crew cab with the 4.8 that I plan on going with a trick turbo kit 76mm turbo, I think 70lb injectors not sure what fuel pump yet. I know I'll need an oil return pump. Is it safe for me to just make a t off of the oil pressure sending unit to feed the turbo with the oil it needs?
Look forward to hearing from you I've seen a lot of bad *** builds can't wait to start mine!
