How strong is the comp timing chain?
Old Oct 2, 2013 | 09:32 PM
mchicia1's Avatar
Default How strong is the comp timing chain?
The chain found in this set
http://texas-speed.com/p-2277-comp-c...iming-set.aspx
How strong is it? Is it better than an ls2 chain. I am swapping my cam, but degreeing it in this time. I have this timing set ready to go in case I need to adjust the cam timing. However, if the chain is stronger, I was thinking of throwing it in regardless even if I don't have to adjust anything.
Anyone have experience with this chain?
Old Oct 2, 2013 | 10:44 PM
RonSSNova's Avatar
Comp hex adjust? If so, it's made by cloyes, same set.
It will be nice and tight, no slop like the LS2
Old Oct 3, 2013 | 04:17 AM
vettenuts's Avatar
Yep, that is a Cloyes. You can tell by the part number. The chain is the same as LS2, it is made by Renold. I was told this by Cloyes a few years ago.
Old Oct 3, 2013 | 08:08 AM
mchicia1's Avatar
Hmm, so am I wasting my time by tossing it in then? If it's just an ls2, I don't see the point then. Current ls2 chain has about 30k cammed miles on it. I guess it wouldn't hurt to replace it. I just hate that slop the ls2 chain has.
Old Oct 3, 2013 | 09:10 AM
badassracing's Avatar
I believe the cloyes gears are made a little bigger so you dont have that slop
Old Oct 3, 2013 | 11:16 AM
mchicia1's Avatar
Oh nice, that's reason enough to put it on then.
