LS6 Valley Pan Question
Old Oct 23, 2013 | 06:26 PM
Bama99z's Avatar
Well i finally got the correct parts today ( most of them at least ). The only part that I am lacking of the valve cover plug. The parts guy must of transposed the numbers I asked for 12568011 which should of been the valve cover plug, and I got 12568001 which was some coolan bypass tube. I'll have to call them tomorrow and order again
Is there anything else that I need?
Attached Thumbnails LS6 Valley Pan Question-valley-pan-2.jpg   LS6 Valley Pan Question-valley-pan-1.jpg   LS6 Valley Pan Question-valley-pan-3.jpg
Old Oct 24, 2013 | 06:58 AM
01ssreda4's Avatar
Should be good.
Old Oct 24, 2013 | 08:42 PM
Bama99z's Avatar
Lord I hope so I'm tired of running back and forth to the dealership.
Old Apr 5, 2014 | 08:14 PM
LilJayV10's Avatar
Do you use two of the valve cover plugs?
Old Apr 5, 2014 | 10:06 PM
Majestic9C1's Avatar
just one on the drivers side rear.. I didnt use the plug and just used a vacuum cap and pressed it over the nipple. works fine for me.
