Compression check gone POSTAL!! 231 237 What should it be???
I did a compression check on all cylinders and the results are really messed up.
1- 180
2 - 210
3 - 210
4 - 215
5 - 230
6 - 220
7 - 165
8 - 210
What's up with that? I cranked all cylinders untill pressure stopped rising. I thought this cam should only be about 165..
I also did a leakdown all cylinders were under 8% with most being under 4%.
Any ideas what could cause this? OR what it should be?
I have a set of Harlan Sharp Roller Rockers torqued to 22ftlb's. I did check preload as the directions said and I got between 1/2 and 3/4 turn of preload before hitting 22ftlb's Heads are unmilled and I'm running a stock length pushrod.
Thanks Rob
My numbers were:
1-150
2-150
3-150
4-150
5-145
6-150
7-145
8-150
Does this mean that my 5 and 7 cylinder are jacked?
I'm not tryin to highjack your thread. I'm confused also..
Rob
1- 180
2 - 210
3 - 210
4 - 215
5 - 230
6 - 220
7 - 165
8 - 210
Thanks Rob
#7 ain't right. maybe try again. otherwise i'd say bad valvejob/valve or they just aren't closing on #7, since you said leakdown was ok.
#1 ain't looking to good either.
Car is an M6.
As I stated earlier I did a leakdown and all cylinders were fine.
Sure guys are making under 420 but I've yet to see anyone post compression test readings like these. Something is wrong and its not the heads. II'm gonna try the stock rockers tomorrow and see if that makes a differance.
Rob
as for trying again I did all cylinders 2 times and did 7 and 1 four times because I couldn't believe it.
Was there excessive carbon buildup on the pistons in the cylinders that were high?
Never heard of this one...normally I'm looking for the low cylinder(s) ( because something's wrong) not the abnormally high
Hope this helps
Hope this helps
I always use assembly lube when assembling and engine or changing lifters cam etc. I covered the cam with assembly lube before installing it.
I also agree I think the cam is ground wrong. I find it hard to believe that 6 lifters went bad. The motor only has 16k on it so I just reused the old lifters. I will get a dial indicator and check that out. rockers are all still tight and look good.
Thanks Rob
Sorry for all the quick posts, but this one is real interesting...just trying to brainstorm some ideas.
I tried those cylinders 4 times each so I doubt the hose was in wrong 4 times. I'm going to re run the test again tonight with a different gauge and see if I get the same results. Then I'm going to put the stock rockers back on and test it again.
Real intresting but driving me nuts.....
Rob
Rob
Sometimes a bad valve guide can do this as well ie Leakdown would look ok, but during compression the valve would rock and loose a little pressure. I'd hate to think that since they are new heads. Good luck tonight, let us know.
