243 Valve question again
Old Oct 12, 2013 | 09:39 AM
racels's Avatar
Default 243 Valve question again
The valves on the stock 243 heads seem to be awful small. What is the biggest valve you can put on these heads? Who makes the lightest? 4.000 inch bore cyl
Thanks
Dan
Old Oct 12, 2013 | 10:44 AM
outkast6991's Avatar
Without changing the seats I believe the biggest is 2.02. What CID is the motor? Stock 2.0 valves when done right are plenty for most 364ci or less street/strip stuff
Old Oct 12, 2013 | 11:22 AM
PREDATOR-Z's Avatar
Turned down LS3 valves to 2.08, seat will have to be changed.
Old Oct 12, 2013 | 11:59 AM
racels's Avatar
I do not mind having the seats machined if its worth it.
Thank you for the replies.
I do not think the stock valves are going to be good enough for what I want. Its a grudge car. I am new to LS stuff I have always done SBF before.
Old Oct 12, 2013 | 12:24 PM
KCS's Avatar
KCS
Moderator
You can fit the 2.165" LS3 intake valves without turning them down.
Old Oct 12, 2013 | 12:53 PM
racels's Avatar
what about on the exhaust side?
Old Oct 12, 2013 | 01:35 PM
KCS's Avatar
KCS
Moderator
That would depend on the intake valve, but 1.60" easy with the stock seat.
Old Oct 12, 2013 | 02:01 PM
racels's Avatar
KCS you seem to know a lot about valves. Mind if I send you a pm with some more details for some questions. This is a grudge car to make money with so I do not want specs all over the internet.
Old Oct 12, 2013 | 04:07 PM
KCS's Avatar
KCS
Moderator
Sure, go for it
