SCR effect on DCR
I ask this because I'm using a DCR calculator from I believe a guy called pianoprodigy. Using the OEM settings for my engine and the camshaft I'm running and I get 8.65 DCR...cool.
But then when I go change the headgasket thickness to say 0.040 to increase the SCR, the DCR also goes up even tho the cam specs remained exactly the same.
Does that make sense that it would jump that much?
It should only be about 1/3 of a point increase in SCR, and about 1/4 point increase in DCR with that change to a .04" gasket; at least for a LS1 motor.
A 226/234 cam with IVC 40* comes up with 8.6 DCR on stock compression.
The same cam comes up with 9.1 DCR on 11.5 compression.
Maybe I'm just using the wrong calculator.
