Cam install question
Old Oct 14, 2013 | 12:41 PM
FLYNAVY30's Avatar
Default Cam install question
When installing the timing chain, should the timing dot on the cam sprocket be at 12 or 6 o'clock with the dot on the crank sprocket at 12?
Thanks
Old Oct 14, 2013 | 12:55 PM
chevybayboy's Avatar
Cam sprocket should be at 6 crank should be at 12
Old Oct 14, 2013 | 01:06 PM
FLYNAVY30's Avatar
awesome, thanks
Old Oct 15, 2013 | 07:09 PM
joecar's Avatar
It probably easier to align the dots with cam at 6 and crank at 12.
But note that when you spin the crank one revolution from there, the relationship will now be cam at 12 and crank at 12.
