Damaged Rod bolt thread!!
Old Oct 21, 2013 | 09:04 PM
rusty bus's Avatar
Default Damaged Rod bolt thread!!
Hey guys, i was pulling down my lS1 tonight and i noticed that one of the ARP rod bolts was quite tight to undo, Once undone the thread looked slightly burred so i tried to run a clean threaded bolt down rod and it just started to bind up. So in this situation im thinking if i just run a tap down the thread of the rod it should be ok?? Does anyone know what thread a stock LS1 rod bolt is??
Any help would be greatly appreciated!
cheers john.
Old Oct 22, 2013 | 07:49 AM
KCS's Avatar
KCS
Moderator
I wouldn't run a tap, that will cut material out which you don't want to do on a critical thread joint like that. I would consider a different rod just to be safe.
Old Oct 22, 2013 | 11:41 AM
wildcamaro's Avatar
Yea for as cheap as you can get a used rod don't risk assembling with that rod
Old Oct 22, 2013 | 12:39 PM
Cwarta's Avatar
OP I have a partial set of ls2 rods and pistons lmk, I'd sell one cheap if you need it.
