Oil pump swap questions
Thanks everyone. Going to try a 3-foot pipe over my 2-foot breaker bar plus a deep impact socket instead of a shallow thin wall, plus someone in the car standing on the brakes as a substitute for my broken parking brake. If that doesn't work I guess I'm dropping the starter and buying a Ken Moore tool.
I'll also get the 1" longer crank bolt.
What other bolts do I need to take out to get it to move? Do I need to remove the two 15mm bolts from the bellhousing to the oil pan?
Made it so far and I'm stuck on this!
While taking it off the old o-ring was stuck inside the pump, not sitting on the pickup tube. I pulled it out and it doesn't look necessarily bad, but it doesn't really look good either. It looks somewhat pinched but I don't know if it's pinched enough to cause the symptoms I was seeing. The pressure spring looks similar; not necessarily bad, but not good either. It popped up as soon as I removed the housing cap.
Terrible picture of them: (will update with a better pic)
Also, the ported LS6 pump I bought is the same part number as my stock pump. Is this correct?
