2004 4.8 liter bolt torque spec's
Old 11-05-2013, 01:00 PM
jimmls1's Avatar
Default 2004 4.8 liter bolt torque spec's
Hello All, New here. Does any body have a list of torque spec's for the 4.8 liter I have been looking everywhere and short of buying a service manual I can't find then anywhere. I need the following=
Intake and exhaust manifold.
Oil pan and front cover.
Flex plate.
Front engine crank mounted pully.
Any help would be great. Thank You. Jim
Old 11-05-2013, 01:18 PM
Burken01's Avatar
Flex plate.
4.8 liter would use ls1 torque specs since its the same block type, only difference being iron.
http://www.ls1howto.com/index.php?category=1
I attached the sequence for the intake manifold, the oil pan/front cover has its own sequence which is a little involved.
I don't have that diagram on my phone but maybe ill try and find it and reply back..
Attached Thumbnails 2004 4.8 liter bolt torque spec's-image-3332625529.jpg   2004 4.8 liter bolt torque spec's-image-1572500224.jpg
Old 11-05-2013, 02:40 PM
jimmls1's Avatar
Default Thank You Burken01
That was way more info than what was needed This will be filed for future use for sure.
Quick Reply: 2004 4.8 liter bolt torque spec's
